rock soderstrom
Tour de France
Hi guys, is there much difference between tube sockets with or without shielding when using 6.3V AC heater in terms of SNR?
I usually heat PCB based tube circuits with DC voltage but this time I will do it with AC voltage and with separate wiring.
I only have the standard ceramic sockets without metal shielding at home ATM and therefore the question arises: is the difference to the shielded sockets realy that big?
Has anyone compared the two? What are your experiences?
My current project is a Fender Black Face type bass preamp aka Alembic F2B, based on 12AX7 valves. The tubes are mounted horizontally on upright PCBs in a 1HU case, the AC heating voltage is supplied from the component side.
