Ntp 179-240 limiter docs?
WNStudios
I've looked through the document section and Googled my ass off but i can not find any documents on this particular limiter. Does anybody have any, or atleast the pinout? Would be very grateful for all info i can get 😊
In the NTP price list from 1977 you see both the 179-230 and 179-240:
179-230, limiter var. time constants, 24V
and
179-240, limiter fixed time constants, 24V
My guess is, that these are more or less identical, and that at least the pin-out is the same for both units. The 179-230 is in the Technical Documents section. Check it out.
/Erik
Good find, Erik!
Also, in the parts list for that 179-230, the PCB is designated 179-2340 - which could certainly point to being for both -230 and -240
Good find, Erik!
Easy find! The price list is on your very own web page.
And I just found this in an old StudioSound magazine from 1976:
Says that the 179-240 is basically the same as the 179-230, but with a switch for pre-emphasis (like eg. the 179-280 - which is also in the tech section)
The 179-230 has provision for stereo coupling and output to meter. I guess the -240 also has.
/Erik
  • StudioSound 1976_limiter survey (3).pdf
    1,000.2 KB
Aaaaawesome guys! I thought i was a pretty good detective but i have been bested 10 fold! Thank you so much 😁
Please report back, if this is completely wrong. I have updated the entry for NTP 179-230 in the tech section to also cover the NTP 179-240
/Erik
Will do! I'm picking it up tomorrow so should be able to confirm during the weekend 😊
Just got two binders with tech from Sweden and in that i got all the specs etc for the 240 and 240B. Will scan later and upload
Super! I look forward to read it.
Once you have uploaded it, I will remove the 179-240 stuff from the NTP 179-230 section in the tech docs.
What else was in those binders?
/Erik
/Erik
Sorry got a little distracted.
They're for the SR/LRAB PSM 60000 (program servo mixer) they used in the local radio stations here in Sweden, so most of that stuff is in there.
But ntp specifically I got the 177-600 peak programme meter @and 179-240 and 240b only.
Have you made the scans of the 179-240 and 240b papers?
/Erik
