I have two NTP 179-400 limiter cards that I racked some time ago and they are working fine and just sound lovely. There is one thing however that has been puzzling me: when linked for stereo operation, only one meter shows the gain reduction and the other one drops to zero (signal path is not affected by this - it's really just the metering). It's always the meter of the channel with less gain reduction that shows zero, so it's not always the same channel.
In the attached schematic (see pdf for full resolution) you can see pins 26 and 27 where the meter is connected (I'm using a cheap amperemeter from Ebay - internal resistance is 1k, so within the specs of NTP). Linking two cards is done by connecting pin 28 of both cards together.
Has somebody racked these for stereo operation with meters and solved this problem?
