OEP vs Lundahl transformers in the 1176
mfdu said:
i'm running OEP outputs on one pair, and OEP inputs and outputs on another pair.
i gotta say - the units with OEP trannie i/o are stunning.  smoother than the output only units, and lovely tone whether treating them nice or overdriving the sh*t out of the inputs.
i don't think i need to try the lundahls - everyone says they're so clean . . . too clean?
on the basis of the two trannie i/o units, i'm planning on modding the electrically balanced input units to be switchable from electric in to trannie in (using edcor trannies, i thought - for a bit of extra fun and flavour).
chris.
G'day Chris.
Did you end up finding a good way to add transformers and switch them in or out of the input section?
I was wondering the same thing!
Evan.
(in Melbourne, also!)
Just finished an 1176 d build. First one. I did test the power supply and everything was right before I started filling the rest of the board. I completed the rest checked everything and plugged it in. Light came on and looked ready to go. Took it into the studio to calibrate , powered it up then it died. Light died and now no readings at the +30 - 10 rails. Could it be the transformer and if so, could it be tested at the meter switch without taking everything apart? How would I go about tracking down the problem? Because the light went out would this mean that the problem is likely prior to the pcb board? This is why I am assuming it is the transformer. I know I am getting power to the transformer.
Any help would be appreciated. Thanks
Rich
question about the OEPs
OEP A262A2E
OEP A262A3E
What is the difference between the two described? is one input and one output? (if so which way round?)
you'll find your asnwer if you look at the datasheet for each one: http://www.oep.co.uk/products_listing.php?cat=6&subcat=22&subsubcat=47
the 2E is a 1+1:2+2  while the 3E is a 1+1:6.25K+6.25K, but both primaries are 150R / 300R but higher secondary ratio on the 3E (more set up).
you could use either one for input depending on your needs of the circuit input.  as well either can be used in reverse as an output if you choose to do so (but better options are out there at similar costs).
if you're planning to use it specifically in the G1176 (assumed as it is in the thread title), then you would be using the 2E for both in (IIRC prim in series, sec in parallel) and out (IIRC prim in series, sec in series).
hope this helps.
-grant
Hi
I know this thread is old but cant find info anywhere else
Are the OEP A262A2E and OEP A262A3E drop in replacements for the Lundahl ?
I checked the spec sheets and they dont appear to be? Is some creative wiring required to conect these to the PCB?
thanks for any info
It’s a “G1176” revision F but it looks perfect for lundahls.
Yeah it is designed for the Lundhals - I was trying to ascertain if the alternatives mentioned in some posts (OEP A262A2E and OEP A262A3E) were drop in replacements..
thanks
