I built the mic yesterday with a friend. We were very, very careful and kept everything cleen at each step according to the tutorial (with 70% isopropyl alcohol).
PSU worked fine I think. We can easily get +120V on B+ with a 180k screwed beetween B+ and ground; and 6,3 for heater, -1 for bias, checking from the PSU blocks.
Then we removed the 180k resistor and we ran a test with the mike (stock capsule and groove tube 12AT7, FB and RB linked by a jumper). We adjusted the heater from the mic, and B+ and Bias, checking from the PSU blocks. Everything went fine. Then we powered it off, closed the mike's body, plugged it in a preamp (without phantom
), and powered on.
It took about 40 seconds before we could ear a sound but finaly, sound appeared! It was ok, except the noise seems to be too loud, and the audio signal, a little bit to tiny, regarding the stock Alctron we tested in comparison. I thought it was the tube/voltage, so we adjusted B+ and Bias (heater was fine 6,28V) with the same method I described before. The mike was still a little bit noisy and low output.
Maybe we (ok I :
) made a mistake, I thought the tube as a problem, so I switched it for the 6072 nos tube. We readjusted voltages (B+ was down to 104, we put it at 120V), always checking the heater from the mike and the others (B+ and Bias) from the psu blocks, according to the tutorial. While everything seemed to be fine, we ran an audio test.
And... Still the same: not a lot of audio signal ( stock alctron is at least 5/6 dB higher in comparison ), and constant noise. The noise is not so loud, but enought to be a problem while recording. We tested into several preamps, with the same conclusion. :'(
Then it was 3am and we didn't want to destroy something, so we stopped...
What do you thinks this could be? Is it normal? I don't think so but maybe someone as already encoutered this issue?
Some help will be very appreciated
thanks,
Remi
