Okay, it's snowing, I'm unhappy (grave understatement), and it's cold....time for me to gripe !
I've fired up the comp today and have a few comments off the bat.
1st, I've found that (surprise) I had to play with the psu in order to acheive symetric output. I'm not sure if it's a result of using 317/337 instead of the devices that Fred had in his schem, but the resistor values don't work out. It's close, about 25.6v but I'm picky about this. What I've done is replaced the 6k19 with 4k75 and parallelled the 300r with a 500r pot and a 120r in series (didn't have a smaller value pot so I took the long road). Result is a trim range from about 19-27v. and the ability to really dial in the voltage wanted.
The following is in reference to the non discrete build.
2nd, I measured an unwanted roll off begining @ ~500Hz. It's quite steep too. With or without a transformer. I didn't play around with it very long but looking at the schem, maybe we can find an explanation of what's going on.
Schem
3rd, the way that butta has the pot going in that schem, it acts as a fader and not a make-up adjustment. Again, I think it might be best to tie a pot in the feedback to vary the gain of this stage. I didn't try it out yet but I don't see why it wouldn't work.
Now, I must say that I didn't have the sidechain active at the time these tests were made. It was bypassed by simply not installing the bypass switch which feeds the sidechain. I don't see how would cause any issues but I may be wrong.
Comments people.........
