Now I don't think your J201s are going to work because .67mA is higher than the J201s IDSS readings from the Peak tester
But the Peak IDSS readings were with a VDs voltage of 3v, could the value increase if more voltage is used?
The Peak DCA75 has also a curve tracing function, I can connect it to my computer and maybe get IDSS reading at other voltages, I will try that.
I used J201 because that was what was recommended by RT in the project's documentation and page, but I also have plenty of other JFETs in my stash that I could use
Thanks Gus
