Hi All, I'm attempting to recap a sony CP-3B power supply for a C-37A mic. On the bottom of the original 20/20 multi-part caps, there are 2 adjacent lugs on one side and 1 lug on the opposite side. This is one that I removed from the circuit:
I would assume the single lug is the negative lead, but the can is marked "negative" on the 2 lug side - and to make things more confusing, there is an arrow marked "input" pointing to 1 of the 2 adjacent lugs.
I have scoured online for a schematic, and the closest I could find is a drawing for what I think is an earlier version, the CP-2
Some of the values are different from my CP-3B, but it looks like pretty much the same thing. In the drawing, all 6 of the 20mF caps have one side tied to ground, in my unit all of the single lugs share a ground trace. Am I correct that this is the negative side? - this would be opposite the side marked negative on the can??! The can itself does not show continuity with any of the lugs, and does not appear to be grounded in any way.
I had a japanese friend translate these markings-
apparently they mean "special characteristics". He suggested that it is very possible that whoever was in charge of printing english onto nichicon caps in the 50's could have got the translation of negative and positive mixed up, who knows!
There are 3 additional 2000mF caps which I think are marked the same weird way (negative side opposite the negative terminal), since the drawing shows the positive side connected to the large 45 ohm power resistor - is that correct? In my unit this resistor has a different value, but the layout is otherwise identical as far as I can tell.
Is there a way to test this unit with new caps installed without blowing anything up, especially the mic which is my favorite for vocals these days? I do not have a capacitance meter, but I do have a multimeter and access to an oscilloscope. Thank you for any advice!
