Some progress.
Replaced the two DL94 tubes, they are in series so now the DAF91 works. The jan 6418's are still dead, might have to replace them as well.
The voltage now looks much better but still not there, 8,5v instead of 4,5v.
There is a built in voltage meter and when as you can se on the attached images it says 4,5V in red.
Any ideas what to do next? i guess i shouldn't run the unit too long with the wrong voltage, cause the tubes will blow faster, right?
Edit: Replaced two JAN6418's now the voltage is 7,3v. Just have to wait for the last 6418, that would bring down the voltage to 6,7v - but that is still too much.
My guess is that it's been a few volts to much since i bought it, that was why one of the 6418's was out when i bought it. And i didn't use it that long before the complete breakdown.
Best way to fix it? A resistor?
Also noticed that there was no power to the lamp in the VU. Do i dare to hook it up on the same tap as the incoming (should be) 6v?
Soooo many questions...
