Hi all,
Would really appreciate some help here. I have a TAB Funkenwerk v78 preamp that Oliver made custom for a mastering engineer. Uses a different tube in the second stage, looks like it has some special xofrmers etc - whatever it is it sounds great. But the 120Hz HPF isn't working.
I traced the circuit of the LPF section. Also attached is original v72 circuit for reference.
Any reason this isn't working? I thought was faulty cap so replaced but same issue. Switch seems to be working fine too.
As a heads up I am a producer with basic electronic knowledge and super basic tube amplifier understanding. I might be missing something obvious? I don't know how to calculate the RC values so maybe it's doing some kind of 20Hz rolloff since it's for mastering? If I wanted to make it 120 - should I change cap or resistor?
Again any help greatly appreciated - thank you!
![Screenshot 2025-02-05 at 17.03.52.png Screenshot 2025-02-05 at 17.03.52.png](https://cdn.imagearchive.com/groupdiy/data/attachments/97/97194-ac967d9a42474db056e60a9315dfe172.jpg)
