Hi all! It's been a while - hope everyone is well...
I'm off on my theoretical ideas again, and would like to clarify where noise is typically generated in a basic amplifier in the hope of understanding the principles better. Many of you have assisted me in the past with good advice on reducing noise with practical examples - but this time around I just want to make sure that I understand where it's actually coming from, and how it occurs etc... Now I understand that there may be various micro noise sources, but I'm particularly interested in the MAIN source of noise in a basic amplifier here
With the attachment as an example, we have a very basic amplifier setup - an opamp with 3 resistors shown (only two are necessary for the amp stage, but the initial resistor will help with discussion). [EDIT: FYI - the "signal"and "signal+noise"tags are for illustration only - they're not actual sources or anything ...]
The way I understand it is:
*The signal approaches the op amp relatively unaffected - it passes through R70, but with very little current (basically none), there is little noise generated at this point;
*The signal exits the op amp, enters the feedback loop and passes through R72 and then through the drain to ground at R82 --> as we have a current to ground, we generate a relatively large amount of noise through both R72 and R82;
*This noise then enters the negative terminal of the op amp and hey-presto: appears at the output terminal inverted...
Is that right?
If so - that's good! That means I understand the basics... If not, I'd love some one to assist me in understand this a little (or a lot) better!!
Another thing (if my understanding is correct):
I'm a little confused about what happens in the amp stage for the noise... Does this enter the negative terminal; pop out and stabilise itself via the feedback loop at 1:1 amplification? Or does the noise generated at R72 and R82 also actually get amplified? I'd kind of expect it to be amplified, as noise increases with amplification; but I'm wondering if this is just perceived, and that the self generated noise here is just 1:1 and increased with increased amplification because of more current through the R72 R82 resistors (which would be interesting). Of course, in any practical examples: you're significantly amplifying any noise in the original source too; which may add to my perceived understanding of noise increasing as amplification goes up ..
I'd really appreciate any guidance on this topic - just dreaming up more random ideas, and want to understand this topic properly before I dive into anything too deep ;P
Is that right?
