Newmarket
ruffrecords said:However, as the gain is reduced from 60dB to 40dB, the noise at the output of the mic pre drops by nearly the same amount so the important thing, the signal to noise ratio, does in fact increase. Further illustration of the futility of using a single figure to describe performance.
Yes. It's a lot easier to explain with a graph / sketch.
I usually put it in terms of the gain goes down 20dB and the noise goes down too but not by quite as much. But if you need only 40dB gain to get the same output as you did with +60db - with x10 different signal sources obviously - then you're winning.
