3nity
Im using opa134 in a gssl at the inputs instead of a ne5534 and they work fine but in the vca emulation section it doesnt work at all??
Anyone can comment on this?
Thnaks
Thnaks
What do you mean by "VCA emulation"? Is it the opamp that works as a current-to-voltage converter right at the output of the VCA?3nity said:Inputs of the gssl use 5534 and vca section uses 5534...output uses NE5532.
Is it clrear?
Now im using opa134 at inputs and they work, at vca emulation they dont...
Harpo said:The NE5534 compensation cap between pins 5/8 might make your OPA134 unhappy.
