Are you testing with a load? It looks like the regulators aren’t regulating. Are you sure R1 & R2 are the correct values? You’d probably be better off with trim pots in those positions. You should also have the equivalent diodes on D5 on the other two regulators to prevent current flowing through the output of the regulator. Also, I recently ran into an issue where a regulator was not the same pinout as I was expecting, which was a head-scratcher.I have a bigger problem now, though. I finished wiring up the power supply and it's not working. I'm measuring the following voltages:
Transformer secondary: 30V peak
Rectifier +ve: +49V
Rectifier -ve: -30V
+17V output: +48V
-17V output: -28V
+48V output: -7V
I'm pretty stumped. I can't see any problem with the schematic and I've checked all the components. Any ideas?
Here's the schematic again:
James
You dodged a bullet with your FWB footprint, and at least the diode rework is easy! I have found that the libraries in the free ECAD programs (EasyEDA, etc.) are loaded with errors, so always check them carefully. As you gain EE/PCB experience, you will appreciate the value of well designed schematic symbols and PCB footprints. Schematics that are easy to read and understand are essential on large projects involving multiple engineers. And well designed PCB footprints (IPC-7351 compliant) make for good high-volume yield.@DaveDC Yes, I agree, it's just lucky that it ends up being correctly wired on the PCB. But yes, I'm going to try and build up a library of correct symbols now.
The maximum adjust pin current for the regulators is 0.1mA, so with 1k on the output pins, I'll get 1.25mA of current, which seems okay. That would give a power dissipation of about 60mW in the voltage setting resistor on the +48 regulator.
Have a look here and here and you'll see that the -20dB pad is fine as-is. However if you look here you'll see the first reference uses "Type A" phantom switching. You may wish to use "Type C" switching if your console will get used in live sound applications where mics are "split" by literally connecting them to two consoles simultaneously with a Y cable. Type A will load the phantom if one console has its phantom on and the other off, whereas Type C will not . I learned this the hard way during beta testing a console with Clair Brothers...
BTW, your -20dB pad should be AFTER the transformer and/or AFTER C3/4 ... otherwise your P48V will be wonky. You really shouldn't need a -20dB pad on either circuit with your switched gain.
My thanks to DaveDC for putting right my brain fart .. for which I can only plead senility. The THAT datasheets are indeed correct.BTW, your -20dB pad should be AFTER the transformer and/or AFTER C3/4 ... otherwise your P48V will be wonky. You really shouldn't need a -20dB pad on either circuit with your switched gain.
Hmm, good point. It looks like I can't up those resistor values then. If I did, I'd be relying on the external load to keep the regulators working. That's a big power dissipation, though, so I'll need to up the resistor power ratings. I wonder if it's still possible to salvage the board. Possibly not!Don’t forget that the TL783 regulator requires an output current draw of 15 mA to maintain regulation.
