Opinions on wiring line in for external preamp..?
Svart
Atlanta GA USA
ok so my Line and my Mic Inputs both go to the preamp that is in the channel strip but I want to install a switch that interrupts the line in and routes it after the preamp section. Here is the part that I am unsure of.. i plan on running the output of my external preamp unbalanced but would like to keep the option of running the Line In balanced when switched to the internal preamp. I was thinking of just taking the - polarity to ground when switched to the external preamp since this would essentially be grounded IF i were to be using an unbalanced cable anyway.. the input to the next stage is a unity gain FET opamp, unbalanced.
anyone see any problems> I'm pretty sure this will be ok.
thanks! :thumb:
