crazydoc
Here's an update. In very brief testing with the original sensor (Fairchild QRE1113.GR) I've found no significant change by varying the resistor values for either the LED or the phototransistor.
Anyway, I've put together a prototype system to be able to test various devices and configurations.
This first photo is an overview of the system.
Power supply, preamp and headphone amp in the background.
These are the boards for the five different sensors I'll be testing. They were some little boards I found in a drawer that I've had for 30+ years. If you keep something long enough, and live long enough, you'll find a use for it.
Here's a closeup of one of the sensors, a TAOS TRS1722 (photodiode.)
Here's another, the Marktech MTRS9520.
Here's one of the boards, mounted on its base.
This shows a thumbwheel (castor cup) and the spring loaded screw for moving the sensor closer to or farther from the membrane.
This shows the five sensors mounted and wired up.
This is a membrane assembly, using aluminum leaf, a section of rubber PVC connector, and a ring of 1 1/2 inch PVC pipe. The leaf is glued onto the rubber ring while it is compressed with a hose clamp, and then stretched as the hose clamp is released.
This stuff is really difficult to work with as it is so light and fragile. I'd really like some one micron aluminized mylar to work with for its tensile strength.
Here's the bottom side of the assembly.
And here's the finished assembly, ready to fire up. The membrane unit just sits over the sensor board, whose distance from the membrane is controlled by the thumbwheel.
