Hey everyone,
I’m looking for options for a 5 pin wire to wire connector to use for line level AC and to feed 24Vdc to relays, using 22 and 24GA wire inside a console.
Aside from those parameters I would like the option for gold pins for the AC.
i have spent a good amount of time searching on the molex, jst and TE websites and had settled on the TE/AMP 0.062 Commercial Pin and Socket Connector.
They seemed to fit the criteria and work with the crimp tools I have (molex KK type) but I’m not satisfied with them in practice and am pretty confident they will be problematic long term.
There are 2 main issues - first, they are very difficult to actually mate together.
Both the pins and the sockets are free floating in the keyed headers so getting 5 pins to line up is actually harder than it should be.
The pins are tublular and hollow with slits cut lengthwise and then bent in to form a tip. This in practice is fairly soft and if the pins aren’t all seated in the sockets then any pressure deforms the pins making them almost impossible to “reform” to be functional.
Second is that the 22GA and 24GA wire is not crimping well. The wire jacket ends up being pulled to one side or the other of the pin.
I will attach some photos to show what I mean.
i could probably live with one or the other issue if it was something I was going to keep - but I know if these have to reseated at any point down the road by the customer they are going to turn into an absolute mess.
So at this point I’m toying with using two of the 3 pin EDAC 516 series connectors for each because I know they are reliable, but before going that route I just wanted to see if anyone here had any suggestions for connectors they like or have had success with.
thanks so much,
Hope everyone is hanging in out there.
Timothy
thanks so much,
Timothy
