Skiroy
Hey guys Im getting better at undertstanding electronics and come along way. I am calibrating a OB-XA right now and 2 issues have come up I am trying to figure out. Now I dont have a Oscilliscope yet but I have a friend that does, that I am trying to get my hands on for this.
1. On one section of the calibration procedure I am supposed to read a pin on an IC chip to be 5.000V +/- 5mv. This was no problem when I was testing a IC that was supposed to be 0.000V +/-25mv because I used the 200mv setting on mt multimeter. But with the 5.000V +/-5mv the 2V,200mv and 2000mv settings are to small and the 20V is too big. So can a reading like this only be done with an Oscilliscope or are there (consumer priced)digital meters that can test 20V with three decimal places to also test down to 1-999mvs?
2. One another section of the calibration procedure I have to play a note and then play the octave up and adjust the volts per octave trim pot untill the beats are doubled per second. My ear is not that good and would rather have a precise way to do this. So the question is if I hooked up an Oscilliscope and played one note at middle C 261.00 Hz and then the octave up at roughly 522Hz what would happen to the wave? Would it just transform into a 522Hz wave or would 2 waves become visual? How could I do this part of the calibration visually via the Oscilliscope?
