I hoping someone here might have messed with one of these before. I just bought an old oscilloscope on eBay. It's a Bell & Howell 9560. It looks like it was sold as a kit that electronics students put together. It was listed as tested and working so I took a chance and it did in fact work when it showed up. I don't have any experience using one but after messing with a bit, I started to get the hang of it and decided to do the calibration procedure outlined in the original build manual. I figured... couldn't hurt, right? It tells you where to set all controls and switches and then has you adjust trim pots as well as certain controls on the face and eventually a little square appears on the display, which it did. I then realized that I hadn't set ALL of the controls correctly and some of the adjustments seemed more extreme than the manual was alluding to so I figured that was why. I zeroed everything out and went back to square one to begin the calibration procedure once more. At a point, I should have been seeing the little square dot on the display but I wasn't. A bit later, I saw it but it started fading and acting weird and then disappeared completely and I haven't seen it since.
I'm pretty careful with things like this and I don't remember shorting anything out with my probes but it certainly is possible. I asked a knowledgeable friend about it and he said there was probably a flyback transformer somewhere and that is what normally goes bad with a CRT based system. I don't see anything on the schematic aside from the main power transformer which is a multitap much like you would find in a tube amp. One of the windings goes straight to what looks like the filaments of the CRT. As I'm carrying out these measurements and adjustments, the voltages are all there so I'm thinking the driver transistors are probably fine. Just can't seem to get anything on the display.
Does it sound like the CRT is toast? It's ironic that I got an oscilloscope to help me troubleshoot electronics builds and repairs and now I'm stuck trying to repair the scope. I really don't know where to start with something like this. All suggestions welcome and appreciated.
