> How much is neccessary?
For what?
I started with an Eico 427, which claimed 450KC (yes, 0.4MHZ), but even that was bogus. It would not display over 100KHz except as a small blur. I learned a LOT from that piece of crap (good value for price, but still a poor excuse for a scope).
For synthesizer class, I deliberately re-built a scope with 20KHz response. In that application, if you can't hear it, why should you see it? (It also let me use $0.33 transistors instead of $5 transistors, and a major savings in power supply filtering: less MHz can be very much cheaper.)
Transistor loudspeaker amps used to love to oscillate at 2-3MHz. I have a 5MHz scope for that. But the last oscillator I built (supposed to be a headphone amp) would not focus the waves so it was screaming higher than that. And at bcarso's level of skill, GHz screams are possible, and beyond the ability of any home-shop scope to capture. For small personal DIY, you can't possibly afford a scope to cover any possible crap that can come out of a hot amplifier. I think an awful lot of good commercial audio gear was developed with 1MC-10MHz scopes, and some with no scope at all (scopes didn't exist as standard gear before 1935, and were still uncommon when WWII started).
> Including tube gear?
Most tubes can't hardly amplify past 10MHz. Usually the problem is getting to 100KHz or 1MHz. 20mHz scopes are not that expensive new from China or with careful second-hand shopping.
Yes, I had tube FM radios: they did not amplify 0-100MC, they amplified a 1MC band around 100MC. You can, and have to, tune-out the tube capacitance to get past a few MHz, and you usually know when you are doing that. Wire-wound resistors can sometimes tank-up and oscillate; carbon is your friend. Two bottles and a few inches of wire (parallel tubes) can sometimes Barkhausen in the microwave band: tight conservative layout with damping resistors may be cheaper than a super-scope.
> there's an inverse relationship between the bandwidth of a scope and its resolution (Volts/division)
Only if Money Is Constant. If Money is allowed to increase, there are many ways to improve Gain-Bandwidth product. Ringing-up the top octave (at the expense of everything past cut-off) is too-too trivial. Next you take less gain (at higher bandwidth) per stage, then increase the number of stages ("throwing money at the problem"). When gain-per-stage approaches Unity, "distribute" the gain along several tubes feeding a delay line ("throwing big money").
And in the 20MHz-100MHz, a number of $3 chips will boost milliVolts up to Volts, adding gain to low-price low-gain wide-band scopes (though the cost is so low, most scopes have all the sensitivity you need for Signal, and Noise always needs dedicated preamps).
