digitall2000
hi
i am trying to figure out a problem with a otari mtr-90 mkIII
have had some help from some very kind people on a few different forums
plimousse from this forum be the most helpful
but there doesn't seem to be many people that have had any experience
with the mkIII
so i am stuck at point and don't know if i should just move on or not
i have got down to 6.1.9.3 and got stuck there because of the strange
mechanical pulse in the supply side tension arm
we replaced the bearings in the tension arm stands and tension arm rollers
replaced bearings in the two idler rollers but not in the servo or capstan rollers
they seem in good shape
what i have is a mechanical pulse towards the front of the machine in the supply
side reel tension swing arm in rewind mode
here is my scenario
arm tape - tension arms center as they should
play mode - tension arms center as they should tape packs as it should
ffw mode - tension arms center as they should tape packs as it should
rw mode - take up tension arm centers and is solid but - - - - -
supply tension arm has a mechanical pulse in it where about once every
second the supply side tension arm slackens slightly by moving towards
the front of the machine then snaps back to centered position again
then if i use the pad of my thumb and put a little pressure on the supply tension
arm and hold it almost centered the mechanical sound of the machine changes
slightly and the machine rewinds as it should ...... until i release the pressure
so i am wondering if i should move on to see if the rest of the alignment
procedure straightens out the pulse in the supply tension arm
6.1 Transport Alignment
6.1.1 Transport Deck Plate
6.1.1.1 Opening and Closing the Transport Deck
6.1.1.2 Removing the Transport Deck Plate
6.1.1.3 Reinstalling the Transport Deck Plate
6.1.2 Head Geometry
6.1.2.1 Reproduce Head Azimuth
6.1.2.2 Record Head Azimuth
6.1.3 Swing Arm Travel
6.1.4 Fast Forward/Rewind Damping Solenoid Adjustment
6.1.5 Swing Arm Adjustment
6.1.6 Tape Lifter Mechanism
6.1.7 Brakes
6.1.8 Reel Turntable Height
6.1.9 Reel Tension Servo Adjustments
6.1.9.1 Upper and Lower Limit Adjustment of Reel Tension
6.1.9.2 Preliminary Center Position and Gain Adjustments
6.1.9.3 Tape Tension Check
6.1.9.4 Reel Motor Tracking with Capstan
6.1.9.5 Fine Adjustment of Position and Gain
6.1.9.6 Reel Size Detector Adjustment
6.1.10 Capstan Servo Adjustments
6.1.10.1 Capstan Tachometer Adjustment
6.1.10.2 Adjustment of CAPSTAN CONTROL PCB Assembly
6.1.10.3 Fast Wind Speed Adjustment
6.1.11 Adjustment of TRANSPORT CONTROL PCB Assembly
6.1.12 Adjustment of MASTER CPU PCB Assembly
6.1.13 VU Meter Calibration
i know that the MDAs can be a problem on these machines
are the MDAs all the same?
should i swap out the MDAs to see if the problem follows the supply MDA?
is there some wave forms i can look at to see if something isn't getting a proper pulse?
thank you in advance,
lance
with the mkIII
here is my scenario
6.1.2 Head Geometry
6.1.7 Brakes
lance
