peat said:
So i've got this working by having one switch which swaps pins 2 and 3 on the L channel.
As I said before, it works somewhat. There are many limitations, though. You may not have encountered them, but they exist. In particular, someone with different equipment may find that some functionality doesn't work for them.
This then feeds another switch which connects L+ to R+ and L- to R-
Flicking the second switch is a normal mono, flicking both switches gives me out of phase mono (sides)
Seems to work perfectly to me.
Are you doing that pre or post volume control?
I would imagine that putting transformers or an active stage in your monitoring path would be much more crude than this.
In what respect would it be more crude? An active inverter stage paired with an active mixer cannot be qualified of crude. Transformer secondaries connected in series cannot be qualified of crude. Connecting two active balanced outputs in parallels IS crude, more so if they are in reverse polarity. Think about putting to car batteries in parallels, no big deal but still any differences in charge status will result in one of the batteries sucking the other. Now put them in opposite polarity. Indeed, you would achieve your goal of summing them out-of-phase. Would it be representative of anything useful? I won't influence you with my answer.
Do you have any information of how basic mono'ing of signals works in commercially available monitor controllers or console monitor sections?
I have more than basic information. That's all in my previous posts. Passive monitor controllers rely on a number of prerequisite such as floating-balanced low-impedance outputs, balanced inputs; some of their functionalities do not work in the absence of one of these prerequisite.
Well-designed active controllers are similar to those built in mixers. 99% ot the times, all external signals are debalanced and buffered so mono'ing is just a matter of shorting two medium-impedance lines together, out-of-phase involves an active inverting stage, dimming and muting are done via basic DP1T switches, the volume control being buffered before being sent to a balanced line driver that allows driving long cables without HF loss.
Just look at the schemo of any decent Soundcaft mixer (6000, TS24), DDA, SSL, Studer, Harrison, they all do it the same.
