user 125886
Member
- Joined
- Jun 30, 2021
- Messages
- 12
Hey everybody
I'm about to purchase some electrolytic capacitors for the output section of a 1073. I have looked at many neve clones, and have noticed that the caps on the original schematic were two 470uf caps in parallel. Then, years later, Neve increased these to two 670uf caps in parallel. Then, I read, on this very site, that Geoff Tanner said that the noise of the 1073 is directly related to the quality, and the size of the capacitance on the output. I guess that's true seeing that most clones now have values of 2200uF - 4400uF.
Here's my question. I have been seeing the adds for "Audio Grade Capacitors". Should I go with these audio grade caps? Or should I just go for specs like / dissipation rate / low ESR / high ripple current? My instincts tell me this "audio grade" stuff is a bunch of silliness. Maybe I should just put standard general purpose Nichicon caps thru the whole amp.
Also, is 2200uF enough capacitance? Or should I go for 4400uF, like the ez1290?
Any suggestions?
Any suggestions?
