john12ax7
Italian cuisine
Ital is its own thing, it's not Italian
Italian cuisine
Probably. If I'm guilty of BS or bragging, give me an example. I'm ready to have my nose rubbed.Really, I get the opposite feeling. Maybe our relative definitions of BS are at odds,? Same for braggarts?
This is a basic Cohen. Is it your definitive answer?As it seems that in your mind a schematic is required, have one.
It's these "few very minor adjustments" that I would like to see. They're so blindingly obvious that I don't see them.This circuit from a THAT presentation is suitable to be DC coupled to the input, including phantom power, with a few very minor adjustments and the addition of relevant servo's. How to should be blindingly obvious.
We all know the devil is in the details. These minor adjustments usually turn out to be major PITA's.To get rid of these polarised coupling capacitors, their distortion, the required protection circuitry etc., the associated board space, cost and whatsnots is trivial.
It can be done using minor adjustments of existing circuitry decades old with minimum added complications.
In essence, the concept is a diff amp with a CM voltage range of about 55-60V. I believe it requires at least one rail of similar voltage. Maybe I'm wrong. Educate me.It could also easily made into an IC including power supplies from a single 5V rail.
This just shows you don't understand. I don't want to assert anything, I'm just asking down-to-earth questions.In my view you are just not thinking things through, because you don't want to solve the problem posited, which would be trivial.
Instead you want to assert that:
I see. Now is time for dick contests.Hmmm, how many practical, cost-effective working products did you design and introduce to the market? Me, probably easily over 50, not counting minor variations.
Very well.Well, do you know NIH syndrome?
You have just agreed that polarisation influences distortion. Read again. I've never advocated the fact that polarisation improved distortion on a general basis. I just said it changes it, and as such is worth investigating."Influence" yes.
But with the exception of one specific product (Black Gate Audiophile Capacitors - long discontinued) the influence is negative.
Oh no, it IS an old wives tale, because it has been disproven for decades.
I see flaws in scientifid method in all the tests I've seen, including Bateman's.I agree no such thing. It is really well documented.
I'm not categorical. Some are worth it and some are BS. that's why investigating is necessary.These were fairly large tests to see if the extra cost for "BS Snakeoil Parts" can actually be justified in production or if it's just BS. Conclusion, not BS and in mass production definitly worth it.
Thor, this is an unqualified statement and you are wrong.Anyway, phantom powered Microphones are last Millennium, nobody is really interested in much to do with it.
So fake sound is better?Totally transparent pro audio gear is a waste of time as nothing really sounds as good in person as it can be made to sound after recording with hot & fat gear, punchy or smooth as needed,....with the exception of some instruments used to make classical music and the like especially when there is a desire to hear how good that instrument is...a multi-million dollar violin for example....but then the loudspeakers' coloration will swamp out a lot of micpre and recording chain differences.
Sounds like you're a grad of Trump University.There is a winning sound but people not into winning often fail to notice.
Perhaps I was unclear.They do? Transformer's too in some cases.
In other cases they do not have DC Blocking Capacitors and Transformers on the output and use film capacitors for coupling.
Potentially yes.
Why do presume there are these capacitors?
Here a modern ADC Input:
Here a version with the PGA2500 Microphone Preamp:
Look mama! No coupling capacitors.
If it was not for those pesky phantom power blocking input capacitors, we would be "no capacitor" from Microphone to ADC.
So where do you see the "Many Capacitors"?
Depends what sort of capacitors you use and how.
If you use a pair of ~10uF FKP Capacitors they will not add distortion that is appreciable, even though even they will show increased distortion.
Now let's say 10uF FKP are a bit big and expensive, you could use Nichicon Muse ES series "Audio Grade". But they are much bigger and more expensive then generic electrolytic capacitors.
So instead you put generic polarised Capacitors (RVT from Honor). But now we have audible distortion and they still COST MORE than a wire or PCB trace.
So if we had a PGA2500 with my suggested of frontend with ADC, a Microphone based on the Schoeps design we would have literally a pair of Film Capacitors and the capsule as the sole capacitors between air pressure changes and ADC.
Thor
We started back here, with this question and somehow wound up discussing USB outputs from podcasting and consumer gaming products. I'm sure USB microphones outsell professional studio microphones in 2024, but the question wasn't about that.Interested in people's thoughts on what to use for phantom power blocking capacitors in the audio path. There are basically 3 options
1) Polar electrolytic
2) Bi-polar electrolytic
3) Film, if allowed by space and cost
I'm well aware of things like Cyril Bateman's articles. Looking more for any other measurements or listening tests people have done and specific cap suggestions to try.
Thought the Nicicon MUSE ES might be a good choice, but they only go up to 50V. In the Forssell pre, which sounds amazing, seems to be polar Nichicon "audio" electrolytics in parallel with film caps. (The Nichicon have been discontinued).
So, what caps do you use?
Yup... I recall back in the 80s listening to audiophools complain about how many switch contacts were in a given audio path.Perhaps I was unclear.
I meant in a typical real-world use case, there WILL be many capacitors in the entire chain between a mic capsule and an ADC (not that such a path couldn't be concieved of with few or no caps in it). And in such typical chain, would the elimination (or even just upgrade) of only one cap, really be audible?
Just think how many caps are in the signal path of the average analog mixer alone (many still use them, you know).
Hey Abbey Road. You're a moderator on a DIY forum yet you feel the need to personally attack Thor and others, including me one time. Quite frankly if you can't keep your comments civil you don't deserve the title of moderator.I see. Now is time for dick contests.
Very well.
Sorry I can't...Remind me which wildly successful 1980's british mixer maker replaced pretty much ALL mechanical switches with J-Fet's and together with some other minor changes to the old style circuitry revolutionised recording, dominated the serious market for the next decade plus and defined the "sound" of music for Gen X?
And yes, their Mixers sounded SO MUCH cleaner than the old stuff.
Thor
Seriously?Hey Abbey Road. You're a moderator on a DIY forum yet you feel the need to personally attack Thor and others, including me one time. Quite frankly if you can't keep your comments civil you don't deserve the title of moderator.
When I run into these personal attacks on any one they are neither funny or of value and quite frankly it makes me not want to participate. Every one is here because of a common interest.
If you can't keep a civil point of view walk away from the keyboard until you can.
