P channel fet matcher
Help Support GroupDIY:
Spencerleehorton
Felixstowe, Suffolk, UK
Hi All,
Trying to match a few p channel fets and wanted to make a simple circuit to match them.
Has anyone got a link please to a good circuit, I seem to only find n channel fet matchers?
Norfolk - UK
I am no semiconductor expert but, in the best Dr. Who tradition, if you take an N-channel circuit and reverse the polarity of the energy source. it should work for P-channel. :cool:
abbey road d enfer
Moderator
Marcelland
Hi All,
If your concern is matching Vgs and Gm, you can use such a thing:
I use it everyday for appairing transistors and capacitors. Very good $25 investment.
Of course it depends what degree of matching you need.
My view on the subject is that a good design should not need superlative matching; it should be tolerant or provide means of adjusting to tolerances.
JohnRoberts
Staff member
Moderator
Hickory, MS
The last time I matched JFETs was for a phono preamp kit back in 1980(?). Despite being used in the Cohen (cough) topology that should hold the device current relatively stable I measured a distortion difference from using unmatched JFETs with different Vgs pinch off voltages. A bit of a surprise to me.
What I did (not saying its the only or best way) was to try to mimic the actual circuit the devices would be used in for measurement accuracy. For my case a phono preamp front end (basically common source but with a couple k resistor in series with the source to ground. I purchased something like 1k of JFETs and then tested them with gates grounded (0v), 2k resistor in series with source to ground, and drain to appropriate PS rail. I was testing Nch so for Pch test with drain to opposite rail. I basically let them all stabilize at room temperature and wrote down the Vgs on the paper envelopes I put them in. When it came time to sell the kits I sorted through all the envelopes for pairs with the closest Vgs voltages and stapled those bags together in pairs. The preamp used 2 JFETs per side.
I still have some of these JFETs in my back lab, but that's life in the kit business. :unsure: Not very remarkable JFETs but OK for a circa 1980 phono preamp (4.5nV/rt HZ IIRC).
PS; I used a zero insertion force socket so I wouldn't heat the JFETs with my hand's heat while measuring.
Rob Flinn
Sussex, UK
Question based on that there's no such thing as a stupid question. I use a peak dca transistor tester. It measures a bunch of parameters: Vgs (off), Vgs(on), gfs, Idss, Rds. Which of these parameters should I be matching for using fets in a compressor ?
JohnRoberts
Staff member
Moderator
Hickory, MS
It kind of depends on the circuit design, but I will ASSume gate pinch-off voltage (Vgs off?, not sure what Vgs on is). For left and right channel tracking similar Vgs characteristics could be useful. Some designs are looking for a ballpark Vgs range.
Some of those metrics don't seem that germane to compressor design.
-Rds (on) is the on resistance when turned hard on. Useful perhaps for mutes.
-Idss is current with 0V Vgs. High Idss generally correlates with lower noise.
-Gfs (i had to look that one up) I didn't find a clear definition but it seems related to forward transconductance.
Norfolk - UK
Do you have the regular model or the Pro?
ian
Rob Flinn
Sussex, UK
ian
I have the pro model. I can get it to curve trace if I hook it up to my laptop, but the software doesn't seem to have an obvious way to make comparisons. I emailed PEAK about it but they didn't respond.
Norfolk - UK
The two key parameters for FET matching are IDSS and the pinch off voltage both of which the pro model will measure so you should be good to go. I have been toying with buying one myself for some time. Do you think it is worth the money?
Rob Flinn
Sussex, UK
It's quick & easy to use. In the main I just use it for testing transistors when repairing stuff for people. It does this well, but has a whole load more to it that generally I don't use, like the curve tracing for example. I guess there are probably cheaper boxes that would do what I mainly use it for. I wish they would make the software so that you could curve trace a bunch of devices & it would log the parameters maybe in spreadsheet format to make matching easier.
Spencerleehorton
Well using a simple fet tester circuit I seem to have 4 matches quads from 21 fets, 2n3820.
When I say matched I mean with 10% of each other.
Just needed to reverse polarity for p channel as Ian said.
2 resistors 100R and 1meg and a 47uf cap with 3 way switch.
Norfolk - UK
Don't forget if you have an electrolytic cap in there you will need to reverse its polarity also.
IAn
