mhelin
I've got a pair of RØDE NT1 mics which I'd like to use as overheads, but they came without the pad circuits. So which is the best way to implement one? The most usual one must be using a shunt capacitor from capsule to ground which makes a voltage divider. In this case as NT1 uses the Schoeps circuit it may be that it's the PNP output stage which is overdriven first (assuming the FET is biased properly), so it would be also possible to put a resistive voltage divider between the FET and the bipolar(s). Third option would be to lower the bias voltage to the capsule. I didn't found any discussions on this subjects in meta, so I'm asking you what are the benefits and pitfalls (if any) of the different methods. I guess the best option would be no pad circuit at all, but in that case a "Royer mod" of G7 type tube circuit would be needed, right, or is it possible to get large output drive/voltage swing from basic 48V phantom using some other than tube circuit. How about transformer output vs. transformerless circuits, which one's got better headroom?
