"Howland" current pump.
It's kind of unfortunate that the same name applies for a supplier of plumbing supplies (Howland pump & supplies).
Howland indeed. I blame productive text
Back decades ago, I just called them "synthesized current sources". Here is a thread with more discussion from a few years ago (not passive summing). summing large amounts of channels.Howland indeed. I blame productive text
Yes.Thank you Ian, so you suggest to use 10k Ohm pot for inputs, 50k Ohm pots for pan (plus two 22k ohm resistors) and 50k Ohm pot for aux sends, with 47k Ohm bus feed resistors both for the channels and for the aux send. It's right?
Thak you Ian, so, for aux sends intead of 50k Ohm pots I can use 100k Ohm lin pots with te same value of 47k Ohm bus resistors?
It happens however the pot is set. You said you have 18 inputs. So when you send a signal down one of the 47K bus resistors there are 176 other 47K resistors attached to it on the bus. The other end of each of those is a pot of some kind. Even it is is a 100K pot its maximum source resistance will be about 25K so worst case each of the other 17 inputs adds 4&K +25K to the bus. 17 of these in parallel is 4K2. So you 47K bus resistor is connected to ground via the bus by a resistance of just 4K2. So it is effecitvely grounded as far as working out the law of the pot is concernedWhen you say that 47 k Ohm bus resistors are connected from wiper to ground, this happens when the pots are at zero, it is so, right?
Yes This will give 10dB down at the mid point. However, you need to remember that, as far as the load the pot applies to its source is concerned, when the pot is turned right up its resistance is 10K in parallel with 5K. When it is turned right down it is 10KIn this way I can use 10k Ohm linear pot for level, putting a 5k Ohm resistor from wiper to ground?
Thank you again
This depends on what you want to connect it to and how far away it is.Thank you Ian
With 47k ohm resistors the aux output should have an impedance of 47.000/16=2.937,5 Ohm
If I wanto to balance this output, do you think I can use a 10k:10k transformer?
This is a better optionAlternatively I could put an unbalanced to balanced opamp circuit with which I could recover the bus loss, too
You need to turn the switch the other way round and switch the source for each resistor. Attached is a snippet from the routing section of a mixer I am building S2A and S2B do the LCR switching.Hello, instead of pan potentiometer I thought to use an LCR rotary switch connecting to ground the unused resistor in left and right positions.
I've found this schematic, but I can't figure out how to connect the unused resistors to ground.
Does anyone have a schematic that allows this?
Hi everyone. After a few years of inactivity a friend convinced me to help him to build a passive mixer with one fader and pan control per channel.
The inputs are unbalanced
I want to realize the pan circuit with a double pot and resistors and I would like to know if anyone knows of a pcb to make it
A thousand thanks
Assuming we are looking at the switch from the rear, then:As it is not too clear for me, is it possible you have a layout similar to the one I posted?
Be aware that any passive pan without buffering will introduce crosstalk. How much depends on the impedance ratios. This is why commonly mixing amplifiers have "Zero Ohm" input impedance.
How much of an issue this is will depend and should be analysed. Excel is your friend.
In order to keep the interaction between controls low you need a fairly high ratio between summing resistor and level/pan control. High resistance values add noise.
