Hi
I'm having some trouble getting an unbalanced pan pot to fully put the signal on one side or the other. I've tried a few different values, 10K, 50k, 100k, 500k, and 1M all linear, but they still aren't pulling the signal totally to one side. The 1M is getting the closest but then by the time I'm at center the level loss is far to drastic. So far the 50K feels the most natural. Is there anyway that I can add some resistance without changing the feel of the pan so drastically? I know that on some Neve modules they have some resistors attatched to the actual pot. What is this doing? I had just assumed it was to change the taper slightly, but I really don't know.
Right now the Input to the pot is connected to the center lug with the right and left outputs on the right and left lugs. I've tried to use a dual gang pot with the inputs tied together and the grounds tied but it was constantly sending too much of the signal to ground.
Any suggestions?
thanks
Any suggestions?
thanks
