Panning Mixer Modification
RishiRishiRishi
Active member
London
I'm planning on using the attached panning mixer to mix the signals of several mic pres and need to make a few changes to keep the input gain fixed, and also to introduce gain pots to the left, right and stereo headphone outputs.
Since I'll have gain controls on the mic pres, to fix the input level can I simply replace the 100K pots on the schematic to 100K resistors?
To introduce output gain controls to the left, right and stereo headphone outputs, can I simply replace the 39K resistors between 1 & 2 and 6 & 7 of the TL084 for left and right gain control, with pin 1 of the pots going to ground, and pins 2 & 3 of the pots going to 1 & 2 and 6 & 7 of the TL084s?
And do a similar thing for the headphones out, but use a dual pot?
Any help would be hugely appreciated!
    13.6 KB
