I am often impressed by the disconnect between parts cost and labor to effect repairs.
I just repaired the fancy (probably too fancy) control board for my coffee roaster. It has a large LCD display, and three color LED backlight, just because they can... Well the LCD color started acting flaky making random colors, and I was fearful that the LCD was damaged from the cold temps this winter, but upon closer inspection I found that the LED back light was driven by a transistor array that had decided to malfunction.
Long story short I repaired the control board by replacing the $0.60 LED driver array. A replacement control board would have cost me $200... So $0.60 + a couple hours of my time to reverse engineer the circuit and find the faulty component.
Another similar repair where a minor part caused the malfunction. A year ago or more I repaired my neighbors electric wheelchair battery charger. Another case where I had to reverse engineer the circuit to find the faulty part. In that case it was bad resistor, so more like a $0.02 parts cost....
We have all seen repairs that were $0 parts cost, where the product was fixed by reseating the ICs or touching up tired solder connections.
What was your cheapest and most satisfying repair?
