Hi there.
I was wondering whether anyone here could help me with a good formula for a passive summing box with several busses. I always wanted to design a box like that as the idea of analog summing is more about analog parallel processing for me rather than the effect of analog summing itself. Most analog summers on the market just have one bus, I would like 4 subgroups. There is only one widely common product out there, the Heritage Audio MCN32. That one is active, huge and has all these controls I don't really need, in fact rather not have. I also just came across the Undertone Pyra-Sum which is very close to what I wanted to build, but has a slightly different signal flow of what I would like and, quite frankly, considering that it is nothing but a few resistors, switches and connectors a bit overpriced imo. I also think that mono-ing channels can be solved slightly better as you loose the right input completely in their design.
I worked out input impedance, output impedance, resistor values. How would I work out the required make up gain?
Thank you!
Thank you!
