astrovic
Hi all
I decided I needed a passive Vu meter for use in testing, and thought I'd have a go at the one on Kev's website: http://www.diyfactory.com/data/passive_vu_01.pdf
I think Kev has recommended it as a good first project for noobs (like me!) - famous last words!
I've been reading up on dB, dBV, dBu etc today, learning some and forgetting half But anyways, I've got to this (highly simplified) point - if I put a 0dB signal into the input of my passive Vu meter device, I should read 0.775 VAC at the signal input point, (unbalanced signal, testing VAC across the hot and grund pins of the input) right?
And at the meter itself, if that 0dB signal is passing through to the meter (via an appropriate resistor/trimmer as per the schemo) correctly, I should read 0.775 VAC at the meter's terminals, right? AND I should see the needle on the Vu meter sit at 0dB, right?
Well, I've got 0.775 VAC everywhere I think I should have it as per the above. I can adjust the VAC at the meter's terminals by playing with the trimmer quite nicely. What I can't do is get the Vu meter needle to move!
Any thoughts on where I've gone wrong? Is it back to school for me for more theory? :razz:
Thanks for any help - I know it's simple stuff, but we all gotta start somewhere!!
