I'm mostly doing mix/post.zamproject said:Don't you think your preamp output will be plugged in the AD most of the time ?
zamproject said:+ you just have the place in the first row to include "preamp out" in the "outboard out" section
pucho812 said:The live room mics going into the mic pres if they have a normal it should be a full normal not a half normal. Either the mic is going into that pre amp or it is not. If you wish to split the signal, then you have to do things like mic splitter transformers.
Zander said:pucho812 said:The live room mics going into the mic pres if they have a normal it should be a full normal not a half normal. Either the mic is going into that pre amp or it is not. If you wish to split the signal, then you have to do things like mic splitter transformers.
Thank you. Stupid mistake!!
pucho812 said:you can bring the di's up on the patchbay but how do you plan to go from the live room into the di's on the patchbay? 1/4" to xlr? watch your pin out, the di input will be unbalanced, the patchbay will be balanced.
thanks for reminding me! I would have gone with a balanced line to DI.pucho812 said:yeah that should be fine. I was unaware of the female trs ion the live room. carry on.
