PCB Clearout - Various DIY PCBs
trashcanman
UPDATED 03/01/2020
Hey, I'm clearing out my unused PCBs that I've had made for various things. Most of these where made by JLCPCB in China and in my opinion they are excellent quality. They do have a minimum order of 5 though so I have a few leftovers I'll probably never use.
Here is the pricing scheme for all PCBs:
1 PCB - $5 AUD
2 PCB - 8$ AUD
3 or more PCB - $10 AUD
I should be able to send them by letter post which is the cheapest option. Postage within Australia and international will vary between $1.25 AUD and $10 AUD depending on amount ordered.
Payment can be made with PayPal. Send me a message with what you'd like and I'll PM you with a total and payment address.
1176LN REV D  2 Available
This is essentially a copy of the MNATS board minus the power supply and different component footprints. I've made two of these and they work fine. I can provide schematic and BOM. Ratio switch board included with each if needed.
1176 Rotary Ratio Board    6 Available
Lundahll 1540 transformer PCB    1 Available
This can be used with the 1176 boards. Configured as 2:1 step down.
Wayne Kirkwood MS Matrix    2 Available
Copy of this board here http://www.ka-electronics.com/kaelectronics/MS_Matrix/MS_Matrix.htm.
Not tested.
Serge Extended ADSR    10 Available
Info here https://elby-designs.com/contents/en-us/p580.html
Not tested
Mute Relay Control for Yamaha PSU    3 Available
This board replicates the mute relay control section of certain Yamaha power supplies. These power supplies tend to fail so you could replace them with a new SMPS and add this board retain mute control.
