Learner
Hi guys,
I know I really should be diggin into the goodol'area 621 for this but I would really like to get some thoughts on this here as well, I am going to try to finish up my La2a PCB layout with regulated PSU in this term break holiday(next 2 weeks) picking up where I left off end of last holidays. My concern is that I remember reading or hearing from somewhere/someone that it is not good to have tracks on the PCB parallel againest each other, because of the inductance that might interfere with its parallel tracks?
But I guess the inductance is depending on how much DC current is running on the track parallel to each other, is there anything in particular that people should watch out for when doing the PCB layout?
I would not want to complete building the circuit and find out the problem the hard way, it would be a total waste of time finding out it sounds "sh*t" because of the layout is crap.......
I am also very intersted to try the lo/hi pass filter side chain thingy, on the feedback and insert source. Might also implant the vocoder concept using may be 10-11 bandpass filter on the side chain insert to trigger/shape the envelope of the VCA, what about rectifying the 6AQ5A output to DC and incorporate attack and release control to the rectified DC to drive the El panel?
But first I will sort of the regulated PSU and take it from there, might not be a LA2A anymore by the time I am done.........:shock:
Thoughts!?
Thoughts!?
