PCB layout questions
ebartlet
Nashville, TN
I recently built a 2 channel compressor on perf board. I built the first channel. Worked great. Built the second channel which works great. Channel started to oscillate at RF after building channel two one the same board. I fixed this with 33pf caps across the feedback resistors. Now I hear a distorted version of channel two coming across channel one! Not only do I want to fix this one, built I would like to build another one, but with a better layout, as, after testing components, I beleive the layout is the problem. What is recommend for the way power, ground and signals are routed on a PCB?
The answer to that question would be the topic for several full books.
The simple answer is - large tracks for power (lowers crosstalk-through-psu). Small tracks for signal (keeps capacitative crosstalk low). Star ground (keeps references clean)
Jakob E.
[quote author="gyraf"]
Jakob E.[/quote]
Excuse they for kidnapping this Posting :grin: , but what is a good size for the tracks? I mean signal and Power tracks an a PCB.
And what is a good size for the solder pads?
It would be cool if someone could call the sizes for "home made" PCBs and factory made ones. My Problem is somethimes, that i design to small Pads and have trouble to solder it exactly.
Leslie
[quote author="gyraf"]Didn't understand your question..?[/quote]
Oh sorry. My english is very bad.... :oops:
My first question is what is a good size to use as a signal tracks an a PCB and what is a good size for a Power Track.
And my 2. is what is a good size of a pad? My pads are sometimes to small to solder it exactly...
Is a signal track with a thickness of 1mm good?
For power tracks, use as wide as possible, up to some 2.5mm. More for high currents. Depends a lot on copper thickness. You can find tables on the internet about current/width.
My defaults are - measured in MILS (1MIL=1/1000 inch) 40MILS~1mm
Tracks:
signal: 20-30 mils
power <50mA: 30-40 mils
power >50mA: 40-60 mils
grounds: all possible width
Pads:
135 mils - transformers, tube sockets
119 mils - bridge rectifiers, trimmers
106 mils - 1n4001-diodes, medium-size caps
90 mils - ic's, resistors, small caps - this is "standard" pad
69 mils - smallest pads when space is crowded
Jakob E.
one more question Jakob.... :oops:
Are these Pad sizes for "home" made PCBs or Do you use this sizes also when order the PCBs from a factory?
Thanks..
Leslie
[quote author="gyraf"]Both. I always "homemake" my prototype pcb's before sending them off to manufacturing.
Jakob E.[/quote]
Thanks Jakob, so for example a Resistor has always a Pad distance from more than 7,5 mm? In the past i used 5 mm as a distance and had pronlems to solder it good...
My english is very bad, so i hope you understand me....:oops:
Thanks for your help Jakob....
Leslie
Oh I treid it out and for example a NE5534 doesn´t work! The pads are touching each other!
Where is my fault? I am using eagle....
Leslie
Sorry - I don't understand your other question?
For IC pads (and some others) yoy need to specify oval pads to get them big enough without touching. I don't know eagle.
Are you asking how close two pads can be? That depends entirely on voltage differences between the two.
If you're asking for pin spacing, then I always use 4modules (1module=1/10inch=2.54mm) - so a resistor is 10.15mm spaced.
But you always need to know physical size of your components before drawing lay-outs anyway. When in doubt, allow for different components - like I do on several capacitors in the G9
For reference, you should take a look at the layout pdf's found at the gyraf/diy pages. The G9 pcb is closest to how I lay out pcb's these days (some of the other projects are very, very old)
Jakob E.
[quote author="gyraf"]If you're asking for pin spacing, then I always use 4modules (1module=1/10inch=2.54mm) - so a resistor is 10.15mm spaced.[/quote]
Yes, that was my question. Thanks a lot. Now i am on the way.....
I will take a look for the oval pads for my ICs....
Thanks for your patience Jakob.
Leslie...
I found this PCB Design Tutorial a while back and it helped me a lot with the little details.
http://alternatezone.com/electronics/files/PCBDesignTutorialRevA.pdf
Hey guys and girls I'm getting started in doing my very first baby-pcb-layout designs. Could someone plz tell me what size the "standard" pads on the GSSL pcb have? Although the design is super tight and component site is crowded like a free U2 concert ( ;)) I found those very easy to solder... Are they 90 thou? Or even more?
/edit:
And also the drill holes: Are they 1mm?
