Hi!
I recently bought a USB pcm2704 dac very cheap. It is also available at Mouser to build your own pcb.
I thought it is an interesting piece to build around other circuits, and transmit data over USB.
Specifically i would like to build a small MIDI controller with an arduino, and send the MIDI data through usb, while i receive audio through the dac outputs.
The first idea i had to do that is to build a small USB hub with 1 input and two outputs. The input would be for the cable comming from the computer, and the two "outputs" for the MIDI controller to send data to the computer and the second "output" for the DAC to receive audio data from the computer...
I'm not a digital geek... so I ask here if there is a way to transmit/receive MIDI and receive audio through a single usb cable.
Jay x
Jay x
