radardoug
Why on earth would we be interested in some board you did in 1996? Shall I put up all the boards I have done?
What relevance does this have to the thread?
It's really nice from you but I'll learn slowly and by myself, one project at a time, I'm not interested in you redesigning my board but thank you ![I've modified my PCB with your advice] -- GOOD DEAL!!!
[I'll keep you updated] -- GOOD DEAL!!! -- However, should you actually be serious in learning how to do what you're doing now correctly.....it would be wise for you to follow my previous suggestion, which is: >> If you would like to.....send me your "EasyEDA" schematic and PCB-design files and I will take the time to tidy things up and send them back to you. A few KiCAD members on this forum have done that with their KiCAD PCB-design files as they were learning how to use KiCAD and learn PCB-design. It will be far more easier for me to just re-do your design and let you see things than it will be for me to have to write a small booklet here trying to clearly explain everything that's wrong here and how to correct all of your errors using the written word. Your call..... (NOTE: Just simply take all of your EasyEDA design files and ZIP them up. Then, just attach the ZIP file to your response here. Or, you can PM me and include your ZIP file there, instead)!!!
As I have already done with a few KiCAD users on this forum who have sent me their KiCAD schematic and PCB files, I have completely unrouted their layouts and have performed a whole new components placement, so they can see for themselves with their own layout design -- HOW -- much better and differently their own layout can be.....>> IF << they only knew what to do and how to do it. By them reviewing and studying my redesign of their own layouts, they then have a better understanding of things just by seeing how things were done different. In essence, it's a classic case of "it's the same thing, only different"!!! Your call.....
Here's an example of one of my PCB-designs. And.....keep in mind while scrolling through this.....this PCB-design was routed -- one track at a time by hand!!! The routing here was -- NOT -- done by a PCB "auto-router" program!!! Due to certain sensitivities of many of the tracks that comprised this circuit and where they could or could not be routed, I had to click-on each ratsnest net individually and then route it in accordance to the specifications put forth by the design engineer one at a time. This PCB-layout was done by me back in 1996 for a data-telecommunications company:
>> LAYER-1 -- TOPSIDE ROUTES:
>> LAYER-2 -- GROUND PLANE:
>> LAYER-3 -- INNER-ROUTING-1:
>> LAYER-4 -- INNER-ROUTING-2:
>> LAYER-5 -- POWER-PLANE:
>> LAYER-6 -- BOTTOMSIDE ROUTES:
>> So, again.....if you would like to see how your PCB-layout could be "the same thing, only different" and then learn from it.....send me your EasyEDA schematic and PCB-design files. Your call.....
[I'll learn slowly and by myself] -- OK.....that's fine. I was just attempting to help you avoid the common mistakes made when "Newbie's" are learning how to design PCBs, as well as perhaps save you some money from having your PCBs fabricated that end up not performing as well as they could/should have. Your call.....It's really nice from you but I'll learn slowly and by myself, one project at a time, I'm not interested in you redesigning my board but thank you !![]()
>> Are you always so angry???.....Why on earth would we be interested in some board you did in 1996? Shall I put up all the boards I have done?
[I'm not a 3D engineer] -- I'm not either, but I can still do this:If you want to send it, I'd be happy to read the documents you have about well designing a PCB, I'll read it carefully and try to learn new things
For now, I'm happy with the design, even if it's not perfect. I'm not looking to sell a million of these units, it's just one DIY project that I'll build myself and if it performs well, that'll suit my needs nicely.
Thank you for your help on this project, it probably has reached the level of quality I was aiming for (maybe more !) and I still have a lot of work on the physical part of the build as I'm not a 3D engineer but I'll still have to build a nice and clean box around this PCB...
[I finally built this project] -- 1) You have made several changes to your original schematic, but within your original schematic format sheet, you have never updated your "Revision" level. In other words, -- ALL -- of your schematics and your updated schematics all show them as being at "Rev: 1"!!! This will more than likely cause someone else who is copying your schematic to build this device for themselves to not know whether or not they have the latest version. Even with "home" projects, if you are going to publish your work online, you need to still properly detail your documentation. 2) Are you making any progress with the "Receiver" side of your project? Do you know when might you have those design files ready?I finally built this project, and it looks like it works pretty smoothly ! I've tested with 30m distance and no problem at all
I'll post pictures of the finished work (I'm still finishing the enclosures), schematic, PCB and BOM when everything will be done !
Thanks everyone for your help, I'm really happy to have done this![]()
