Yes, I replaced it.Data sheets for the tube say Max plate of 220VDC
Is that with the resistor replaced?
That would be too easy. No. Nothing that I can find so far.Is there a schematic?
Ok, I see. You can measure against the respective cathode (not ground) of the triode system to see how many volts are roughly present at the plate.That would be too easy. No. Nothing that I can find so far.
Yes, that is quite possible, as the triodes in WCF only see half B+ voltage each. The maximum Ufk voltage (6922 --> only 120V) is more of a problem here, but this can be compensated with a elevated heater voltage.I have seen 6922’s at 275VDC on the plate in WCF designs and they held up surprisingly well.
