[quote author="radiance"]So,..... how's the project goin' Svart?
or did I mis something
![Oops! :oops: :oops:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
[/quote]
This thread looks a little long in the tooth, but is an area I have some interest and familiarity with.
One poster referenced a Steve Dove "chapter". I recall a series of articles he published in Studio Sound magazine back in the '80s that were quite good. Steve is a solid designer who has actually walked the walk (Alice consoles in GB among others).
I would offer a few cautions or suggestions about console design. #1 look at as many schematics as you you can find and try to figure out why they did the little unobvious stuff. Consoles are probably the most difficult "simple" circuit (next to power amps) you will encounter. Just like power amps get progessively more difficult as you scale up power, consoles get dificult with increasing numbers of channels.
My second caution is be very aware that ground cannot be zero volts across a span of several feet even with brute force copper bus bars or whatever. Be prepared to take advantage of differential circuitry to forward and back reference signal grounds (opamps are good for something after all).
A third is try to keep absolute polarity straight if you have inserts and/or sundry opportunities to alternately patch signals in and around your signal chain.
Finally the heavy lifting in mixers is the mic preamps and summing buses. For only 24 channels to L/R, the noise gain of less than 30 dB is probably manageable with modern off the shelf parts. (I once did a console with 112 inputs to L/R but that's a somewhat different animal).
PS: perhaps a minor point but "bus" is spelled with one 's', if you look up "buss" in the dictionary you will find a verb that is unrelated to electronic design (and more fun).
PPS: I am an old fan of 5534 as it was a great part in it's day and still pretty serviceable applied at modest gains. One possible concern for the tweaky types (I'm sure there's none here :roll: ) is the extra wiggle in the open loop transfer function well up into the audible range (look at Bode gain plot on data sheets). This is no doubt related to the technique they used to compensate this older process part to get decent GBW and slew rate. I think they called it "split-pole compensation" or something like that. I'm not making any claims about actual audibility which should be down in the dirt for any credible application, only pointing out that there are better looking (on paper) modern devices. Since I presume for many the time investment is larger than the parts cost this may be a consideration.
