PEV500 (Neumann PEVb / PEVc in API500 format)
[silent:arts]
Berlin, Germany
While looking on the Neumann PEVc schematic floating around the web I always thought this would be a cool project for a 500 series module. We found that there were several different versions of this EQ, some with 4 discrete op amps (Neumann OA10), some with 5 discrete op amps, and there was also a PEVb with different gain steps.
For our PEV500 we decided to go with five OA11N op amps, our own mixture of the Neumann OA10 and OA12 using 10 transistors each. Gain steps are either original PEVb, PEVc, 1 dB steps only (PEV-M1), or 0,5 dB steps (PEV-M2).
PEV500 Schematic
PEV500 PCBs
PEV500 Parts List
PEV-B Resistors
PEV-C Resistors
PEV-M1 Resistors
PEV-M2 Resistors
OA11N
#PEV500 on Instagram
Hi Volker.
What is the difference in the gain steps of the B and C?
Also the difference in transformers.
I’ve got a pair of old W491’s and a pair of W695’s I racked up.
I love them.
I’ve heard pev’s sound fantastic and are hard to find.
These look awesome.
I’m kind of interested.
Andy
PEV500 Schematic
PEV500 PCBs
PEV500 Parts List
PEV-B Resistors
PEV-C Resistors
PEV-M1 Resistors
PEV-M2 Resistors
OA11N
Hi Volker.
I love them.
These look awesome.
Andy
B : high and low are 0 3 6 9 12 15 db steps
C : high and low are 0 2 4 6 9 15 db steps
@Andybb
Like @ratrace posted the gain steps for 60 Hz and 10 kHz are ± 3 / 6 / 9 / 12 / 15 dB with the B version, and ± 2 / 4 / 6 / 9 / 15 dB with the C version.
The mid band is identical (± 2 / 4 / 6 / 8 dB).
For your transformer decision the most important thing is the level you want to drive them, the Lundahl is fine up to 15 dBu, if you have higher levels take the Pikatron.
Hi @[silent:arts],
I just emailed about a pair of PEV-Cs and am curious if there is an assembly guide?
Thank you!
Just finished my pair of C’s w Pikatrons!
I’m overjoyed by how thunderous, punchy, tight, clear, and vibey these things are. So far I’ve only tested on synth bass, drum buss, and mix buss and I’m blown away! The magic and weight that these add as soon as you insert them (with all settings at 0) is enough to justify the cost of admission. Even at extreme settings, these hold up extremely well. Compared to a UAD Pultec I had on a mixbuss, the former sounded hazy and loose compared to the PEV’s. 11/10 would consider having a rack of these!
I have to also mention that Volker is an absolute delight to deal with. Thank you for making amazing things!!
What is the purpose of (optional?) RT*1 (620Ω)?
I don't see it on the original Neumann PEVc schematic.
Schematic says, If it's installed, R*18 should be 47Ω; if not it is 1K6Ω.
Just finished building the DOA's and I did a continuity test on the pins. It seems that the labeling of the "COM" and "OUT" pins is reversed in the OA11N pdf.
Hi Volker, loving this project.
Query re the M2 resistor set, there is a discrepancy between the PCB values and the resistor list in your docs.
R544 is listed twice in the list and missing R545
Should R544 be 2k2 and R545 be 1K6 as on the PCB but not as in the resistor list?
The discreet DOA test board has been great BTW, tested all the OA11 op amps before moving on.
They all checked out OK....
The PCB values are always right, sorry for the mistake in the resistor list (corrected).
I guess there was a 2K4 in the kit - do you have two 2K2s handy, or should I send them to you?
Btw, very nice detail with the thermal coupling of T1 & T3 👍
Hi Volker, thanks for clarifying.
If you can stick the resistors (for two kits) in an envelope I'd be very grateful: I moved recently (which is why it's taken so long to start these) so not sure where all my parts boxes are exactly...
