clintrubber
What kind of functionality would you suggest for a little gizmo
that plugs into a mic-pre input and does a few checks for not
too unlikely potential phantom power errors ?
This will be overkill for me, but to keep ribbon-mics alive and to check
if there's a healty voltage available that little phantom test circuit
from Jensen came to mind:
http://www.jensen-transformers.com/as/as038.pdf
So I was wondering if it would make sense to add some stuff
to it to detect eventual unbalances in the pin-2 & pin-3 voltage
while equal currents are drawn from each leg.
Thought behind this is to detect the unlikely situation that both legs
are not created equal (one of the two 6k8 resistors bad for instance)
and that a ribbon-mic could be hurt, even while it's not 'ground-referenced'.
I can imagine this could actually happen by transients
when the 'wrong' voltages are stored on AC-coupling caps.
So I'm all ears for suggestions, any hints & sanity checks welcomed.
Like do we really need a check for DC-unbalance ?
Eventual suggested functions will be easily addible to the circuit,
but as said I'm mainly interested in what one actually really needs
before going crazy with checks for all kinds of highly unlikely events.
If we come to the conclusion that nothing needs to be added actually
then it'll be the Jensen-circuit and I'll apologize for using Drawing Board
bandwidth :wink:
Thanks / regards,
Peter
bandwidth :wink:
Thanks / regards,
Peter
