EKADEK
meet RAY. hes made in zurich early 60s as a reverb/p.a delay system.
i found him shoved at the back of ray's garage shed in 2000 and have rebuilt him slowly over the last years. the disk spins at 600 rpm (or 300) past an erase - record - and 4 playback heads ... which are set within a circular slot around the disk. the disk edge is oxide coated and the heads are carefully set 20/1000 " off the oxide surface. the 4 playback amplifiers are mixed and set to regenerate in an input/output/regen mixer to recording amp. there is a monitor amp and speaker as well.
i need advice regarding renewing the oxide surface. a paintable substance.
