hitchhiker said:
Thanks again, that does look like the right connector.
On looking again, the ebay one has the nice, old-school wrinkled finish metal housing, the other one is the cheap plastic.Tthe ebay one would be the one to get, assuming your supply actually works. Otherwise, what's the point?
I'm guessing the 30 volt is the 10 amp fuse and the 24 volt is 3 amp?
No way to tell without measuring, the 5V may well be handled by the 10 amp fuse., powering a bunch of logic downstream. It would have been nice if they labeled the fuses by what they covered.
Safest way, power up, measure and write down what voltages you get at the output connector, draw a pinout. Note that there may also be main voltages in that connector to extend to something else, be careful. That connector has a lot of pins for only a few voltages, it is an unknown and should be treated as such. It also may be dead, waiting for a confirmation signal to say "OK, I'm plugged in to a load, I can turn on now", this is much more likely if it is a switching supply.
Once you have mapped out the voltages, remove each fuse one at a time, and see what voltages go away. One of those fuses may be for the mains.
If those voltages are useful to you, that's great, you have a free bench supply. If not, a hefty 12V lightbulb in series with the +15 will make a decent trickle charger for your car battery. ;-)
Gene
