dmp
Those of you with plate reverbs...
Do you have to use noise reduction regularly?
How quiet can you expect the output to be? Mine has a noticeable noise / buzz - worse on some pickups than others. (It's fine for rock but not acoustic / folk)
Mine has 4 piezo pickups with cables running to the end (5'-6'), plugged into a active DI. I think the unbalanced lines of the pickups are picking up noise/buzz. I'd expect the plate to have some amount of self noise as well?
I was thinking of putting DIs much closer to the pickups OR running the pickup cables through conduit.
