[quote author="mediatechnology"]
John I think in his scenario it might. Consider the same mic multed into two preamps, one inverting, one not, both brought into channel inputs. I can see how having some inverted, some not, would be a real PITA (even with the inputs not multed) in mic'ing a drum kit. He probably is constantly having to invert the polarity of some preamps for them to sound right particularly when they're used with the ones that don't.
[/quote]
If I understand correctly, a single mic feeding multiple outboard preamps, feeding channels of a mixer.
If the outboard preamps are balanced input and output, and a positive zig on either input pin 2 or 3 results in a similar positive zig on the same output pin, it doesn't matter. If it's XLR in to 1/4" out, or the input doesn't agree with the output, it matters.
I am not familiar with seeing many mics wrong. Even back 20 years ago when it was almost 50-50 between pin 3 and pin 2 hot, the mic guys seemed to have their sierra together (pin 2).
If I had an inventory of mics that varied in polarity, I'd be real tempted to rewire the mics. Note: It might be easier to check for polarity by comparing to a known (or determined) good reference mic when both are listening to a LF tone. They will either combine or subtract when summed in a mixer.
