Sorry if the questions not clear...
I've searched around for as many mixer schematics as possible. The problem is that no mixer I have seen is configured like what I am aiming for.... The usual arrangement (that I am sure you're familiar with) is for each input module to have it's own buffered fader, this source then feeds a number of busses, and the level of each bus is controlled by means of a buffered fader after the bus mix stage.
Say I have four sources, and four busses. All the sources simultaneously feed all four busses...so each bus sees the same four input sources. What I need to be able to do is have a seperate level control for the signal between ONE of the sources and each bus mix stage, so that the level of this source into each bus can be controlled without effecting the other sources levels in the bus, or the level of that source into the other 3 busses.
My question was really if it makes sense (or works at all) to buffer after these pots to raise the parallel R, and improve the load seen by the source that has to feed the four pots in parallel. I would have to use quite large value pots to keep the load reasonable, and I wondered if lower value pots with following buffers would be a better option in terms of noise and loss of signal.
