Hello there,
I'm currently prototyping/building my own synthesiser which use ±15V on the supply rails.
The front-panel board which hosts all potentiometers will sometimes short the +15V rail to GND when all potentiometers are soldered in.
I simply can't find the problem and it makes no sense.. sometimes I will remove some pots again and the short is gone.
Then I solder the same potentiometer back in and it's not shorting. Makes no sense.
What I found out so far: When I select the 100k potentiometers which are directly connected to the supply rails, to a higher value, let's say 110K, the problem will not occur.
Has anybody any clue what it could be? I've never experienced anything like that before.
