Hi.
I'm making some additional aux sends on my mixer. Pots are 10k Log (one side signal, other side ground, middle is regulating level to aux bus), feeding aux buss through 22k resistor. I need 64 pots, four on each of 16 channels.
There is a chance that I get quite cheap, good quality pots, but there is no 10k log. But hey have 500k log and 1k log. They are both way off original 10k, I know, but would it work anyway?
1k may be ok for NE5534 output stage, is it? Or is it not enough? Should I put some additional resistors between ne5534 and 1k pot?
And 500k I could parallel with 10k resistor, and this would give me 10k pot, just log curve would change, is it? Or maybe I could just use 500k instead of 10k, without any parallen resistors? Would it work?
Is it that 500k would be much worse regarding noise, or is it just the same?
What do you recommend instead of 10k log? 1k log or 500k log?
thnx
thnx
