I'm mounting an MCI JH600 preamp and I have some questions/doubts about the power rails.
For those interested, here is the circuit:
The circuit is powered using +/- 18V. On the power supply section, we just have two 100 ohm resistors to lower this voltage a bit and a few filter capacitors.
When I power up the circuit with my lab power supply, I can see that initially the current is about 20mA on each power rail. After one minute, the current raises up to 180mA (especially the -18V) and the 100 ohm resistor starts to overheat.
1. Is this current growth "normal" ?
2. At 20mA, the power for 18V would be 0,36W so my 1W 100Ohm resistor is fine. But at 180mA this gives me 3,24W, hence the overheat. Now, I = U/R, thus 18/100 gives me those 180mA but to me it would mean that the opamp is shorted... Am I wrong somewhere?
Any advice would be appreciated!
